    3DVia Launches Shape2.0: Just a Google SketchUp Clone?
    10 Posts 5 Posters 715 Views 5 Watching
      toxicvoxel
      http://www.solidsmack.com/3dvia-launches-shape20-just-a-google-sketchup-clone/2008-09-16/
      • soloS Offline
        solo
        How is the poly support?
        http://www.solos-art.com
        • K Offline
          kwistenbiebel
          Which Render Engines does it support?
          Any texturing tools additonal to what SU has?
          Animation?
            AndriyG81
            i have tried it before when it was early beta, and honestly did no see a single thing that would make it better then sketchup at that point. Would be curious, what they did now
            http://andriyg.com
            • K Offline
              kwistenbiebel
              I believe the major advantage of Sketchup over the clone is SU being a 'platform' (3td party plugins, render engines,3D warehouse, etc...).
              Via shape will never be able to catch up...at least not when they don't provide extra things SU hasn't got.
                3D warehouse
                Hum hum You can reuse any model of 3D Warehouse ๐Ÿ˜‰
                Just reload it in 3DVia in kmz or OBJ format by example so no problemo ๐Ÿค“ (you must have SU of course) ๐Ÿ˜‰
                Limitation of Shape 2 is : don't works with SP1 ๐Ÿ’š
                Documentation
                They don't say Push Pull but Push 'n Pull ๐Ÿ˜’
                Formats supported and recognized ๐Ÿ˜ฒ
                  Format kmz from SU must be Google Earth 4 else default kmz yet works not!
                  here import Dryad, Moi, Wings3D, SU, Topmod
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=3700.0;attach=5132;image
                  There is yet a section Google Sketchup ๐Ÿ˜‰
                  • K Offline
                    kwistenbiebel
                    Does it run smoothly when having a lot of high poly components on screen?
                      I can't answer you because I can't run it ๐Ÿ˜’ (don't works without SP2)
                      But I have asked ๐Ÿ˜„
                      A simple componant must have less than 2 megas in 3dxml format !
                      There is also a limit as you can't save something on your own hard disk!!!
                      Only on the external server 3DVIA!
                      On 3DVIA limit seems now 100 megas!
                        OK I can answer you ๐Ÿ˜‰
                        For the example with some objects above that was fluid but more you add objects and material more that becomes slowdown ๐Ÿ˜’
                        Shadows are possible but only projected on the ground not between objects or auto shadows!
                        That's real time ๐Ÿ˜‰
