    Sketchup web exporter.
    2 Posts 2 Posters 497 Views 2 Watching
    • M
      mus257
      Anyone know how to modify the code of swivelbutton.rb to just rotate about a point? i.e. a 360degree view from a seat in a theater with a camera visibilty of, say, 30 degrees? Whatever the active camera angle happens to be when it's run. I've been trying to edit the code and I can keep it from zooming the preview before you execute the export, but then it still zooms extents on export.
      • P
        Phil Rader AIA
        I'd welcome this as well.
        I've developed my own manual work-around to essentially create my own images and substitute them for the ones created by the Sketchup web-exporter. Once you generate one web export say for 36 images you can re-use the html code multiple times and simply replace the images with those that you create on your own.
        see my post here:
        404 Not Found
        (www.sketchucation.com)
        http://www.philrader.com
