    Sketchup web exporter.
    2 Posts 2 Posters 468 Views 2 Watching
      mus257
      Anyone know how to modify the code of swivelbutton.rb to just rotate about a point? i.e. a 360degree view from a seat in a theater with a camera visibilty of, say, 30 degrees? Whatever the active camera angle happens to be when it's run. I've been trying to edit the code and I can keep it from zooming the preview before you execute the export, but then it still zooms extents on export.
        Phil Rader AIA
        I'd welcome this as well.
        I've developed my own manual work-around to essentially create my own images and substitute them for the ones created by the Sketchup web-exporter. Once you generate one web export say for 36 images you can re-use the html code multiple times and simply replace the images with those that you create on your own.
        see my post here:
        404 Not Found
        (www.sketchucation.com)
        http://www.philrader.com
