[SK-Indigo] Lights
I'm trying to set light to my model but when I start rendering, that area I selected for light is just black. No light at all, it's even more darker than normal. I made new white material for light and double-clicked material and Indigo window shows up, then I select light from the Assign Preset. That's pretty much all I did. What went wrong?
It sounds like your light isnt powerful enough. You can either set the environment to 'SU background', then tick black. Or you can wack the power of your light right up.
Or can you check if the face you assigned the light to is a front face... Only front faces render properly.
modelhead, not necessarily. You just need to turn the power up a lot if you dont set the background to black.
