    View parallel to section ?
    4 Posts 3 Posters 891 Views 3 Watching
      mangrove
      Hello
      Is there a simple way to obtain a non perspitivic view which is parallel to the section plane. In my case I have to produce severel section which I want to export to a DWG file but my builing is not parallel to X an Y axis.
      Thanks in advance.
      Mangrove
      SU 6 Pro, Xp Pro 64
      • Chris FullmerC Offline
        sure, go to paralel view mode. Then right click on the section plane and select "align view". It should line it right up. Hope that helps!
        Chris
        All my Plugins I've written
        • DavidBoulderD Offline
          DavidBoulder
          I believe you can also export the section cut directly.
          (file/export/sectionslice) Under options like you can do it orthographically or as screen projection
          David Goldwasser
          OpenStudio Developer
            mangrove
            Thanks a lot for your answers, thats exactly what I was looking for.
            Mangrove
            SU 6 Pro, Xp Pro 64
