    Grid Lines of Smoove Command
    2 Posts 2 Posters 437 Views 2 Watching
    • X
      Xydus
      How can you hide the wire frame of the grade without removing the wire frame of the building?
      • R
        remus
        If im understnading you correctly, you can just select all the lines you want to hide then right click one of them->soften/smooth. Youll then need to play about with the slider untill youve softened all the lines.
