    Acuracy trouble
    5 Posts 4 Posters 688 Views 4 Watching
      bhnida
      hi folks,
      i found trouble on using the value box in right lower corner.
      if i input for rectangle's values like 100,200 i do not get the proper rectangle if i put measurement to with tape ore it i get a rectangle of like 100 to 200,2
      were is the ,2 coming from ?
      watch out: if i put 100;200 everithing seems to be correct.
      why makes the , and ; a difference ?
      thanks for answer Bhnida
        remus
        I had a quick go and i cant recreate this πŸ˜‰
        Is it a consistent error youve found?
          This is because you are not using an English language OS. This is an extract from the Users' Guide:
          The exact format for VCB entries will vary depending on your computer's Regional Settings. For European users, the list separator symbol may be a semi-colon instead of a comma, so the format would be
          [x; y; z].
          So that comma is taken as a decimal separator therefore the issue. (I also have to use semicolons which makes some functions of SU impossible for me to use)
          • CraigDC Offline
            CraigD
            Gaieus is exactly correct. πŸ˜„ Thanks Gai!
            Cheers,
             - CraigD
            Google SketchUp
              bhnida
              ok
              this dose not explain why it is like this but i know how to behave not having this trouble anymore.
              lets blame it on the endles nirvana of programming reasons πŸ˜•
              thanks for your help πŸ˜„
              cu all.
              PS:off topic message
              WANTED DEAD ORE ALIVE
              looking for programmers experienced in linux audio projects ALSA and JACK brute fir and so on πŸ˜‰
              real money to be made with us... good and fair payment
