    [REQ] wire lines to tubes
    8 Posts 5 Posters 2.1k Views 5 Watching
    • G Offline
      gaucho
      Hi guys,
      would be possible to do in ruby script, something to generate from a wire mesh... like single lines, a tube mesh? or even square extrude elements... (maybe options to choose from)
      I know there's something like it in the 3DS...
      Any volunteer?
      Thanks in advance!
      Trying to make this...
      ...turn in to this!
      "eat well, stay fit, die anyway..."
      • G Offline
        gaucho
        I've uploaded two images to ilustrate the issue!
        Thanks!
          remus
          You could try using the technique described in the attached tutorial, ive found it to work quite well for things like that.
          mesh structure tut.skp
          • G Offline
            gaucho
            Thanks for your reply remus.
            I think it is a little bit more complex as in this case the mesh is not in a single plane, it's a curve canopy and my experiences with FFD never came up with a good precision in the end...
            • Didier BurD Offline
              Didier Bur
              Maybe you could use line2cyl.rb ?
              Selectionable tube diameter and tube precision, but no intersections between cylinders 😕
              Here roughly applied on a basic terrain mesh.
              line2cyl.rb
              DB
              • 2 Offline
                2myChaGrin
                Didier,
                Would it be a difficult thing to modify this script so that it will paint the cylinders to a color, namely black. I use this script quite a bit as a means to show lines to a render engine. I usually convert sketchup lines to 1/8" cylinders (usually for brick borders around curves or anywhere I want to stylize the final output) and I usually have to go back and paint each cylinder black. This can become a chore with a few hundred separated lines (cylinders) that are 1/8" thick. Something along these lines would be good as a "render line" ruby (if cylinders didn't create so many extra polygons!
                • bigstickB Offline
                  bigstick
                  I use 'pipe along path' which gives you an option to set the number of segments for your cylinders. I often use just 4 or 5 if they are for something which isn't close to the camera.
                    Didier Bur
                    Hi all,
                    Here is an update of line2cyl.rb:
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12354
                    Selectable material, grouping, follow-me when possible, and some other enhancements.
                    Regards,
                    DB
