    Component/Group from Layer/Material?
    12 Posts 4 Posters 1.3k Views 4 Watching
    • thomthomT
      Is there a ruby that will take a mesh and separate geometry by layer or material?
      • Chris FullmerC
        I think this one does what you want.
        http://www.smustard.com/script/GroupByLayer
        Chris
        All my Plugins I've written
        • thomthomT
          Does it work on selections, or does it take the entire model?
          • thomthomT
            I just tried it, and it modifies the entire scene. That doesn't work too well for me.
            The problem I'm having is that when exporting from Revit allot of the geometry is joined into one mesh, but various types are on different layers. But I also have a number of groups, such as windows and door which I want to keep as is. If that script worked on selection it's do the job perfectly.
            I really should get into Ruby, then I could have modified it.
            • R
              RickW
              Tell you what - I'll modify it for you 😄 Just give me a little while...
              RickW
              www.smustard.com
              • thomthomT
                I love this forum!
                Thank you very much. The people here are awesome.
                • M
                  Matt666
                  Hi !
                  Look at here, there is an early script can do what you want. there is still a problem (subject of the message) but it works if you killed Bryce 👿
                  Hi Rick !
                  Yeah ! I'm in a hurry to see your code 😄 !!
                  Thank you !
                  Frenglish at its best !
                  My scripts
                  • R
                    RickW
                    Testing the update now...
                    [EDIT] The remaining problem to be solved is that an exploded group/component will create "unreported" geometry if a new edge is created due to an edge from the g/c intersecting with an edge that was outside the g/c (think of a "T" where the top edge was in the g/c and the leg was outside the g/c). This geometry is not yet handled by the script, since SU isn't reporting it along with the exploded geometry. I think I need to write an observer to check all geometry created during an explode. 😒
                    RickW
                    www.smustard.com
                    • R
                      RickW
                      Okay, so what is the consensus - wait for the observer to be written/tested, or release now and update later?
                      RickW
                      www.smustard.com
                      • Chris FullmerC
                        I can wait. But then again, its not me who needed the script.
                        Chris
                        BTW, hows it going Rick? Good to see you around. I don't post in this forum too often, so I haven't really said hi since basecamp.
                        • thomthomT
                          I can wait for the observer to be written. It's not a rush thing for me, just a very convenient tool to have. 😄
                          • R
                            RickW
                            Okay, hopefully I can get the observer written and working next week.
                            RickW
                            www.smustard.com
