Textures won't render
Ben...could you call back to Podium forum....It will be solved much quicker over there.
Sepo, I'm running the windows version.
Frederick, the textures is coming from the materials folder under the SU program folder. No unusual characters in the folder name.
Thanks again guys. Ben
I would have prefered to deal with it on Podium forum but ok....tell me what you have in your Podium folder in plugins.
OK... Then I'm out of ideas...
I'm sure Sepo will be able to help you out here...
Perhaps you should take his advice and continue this on the Podium forum...
solved...issue of permission to write the textures.
Thanks again everyone. Like Sepo indicated, problem solved.
Ben
I have the same problem, can someone explain how the problem was resolved.
Regards
Tim -
Tim it about permission to write textures....go on the Podium forum....we have a tread about it.
Hi Tim, welcome to the SCF!
See the post two places up from yours...
For the uninformed (i.e. those of you that don't check previous posts), this was using the Podium rendering software available for SU. A recent decision by management to throw all the toys into one basket and let you sift through it yourself resulted in the forum as it is now, somewhat overwhelming and disorganised.
Register LoginAdvertisement
