    Textures won't render
    extensions
    29 Posts 7 Posters 8.8k Views 7 Watching
    • FrederikF Offline
      Frederik
      I seem to recall having had a similar issue when exporting a model using the free Google SU with only the standard material package installed... (the package, which is installed together with GSU)
      I suggest you download the Materials Bonus Pack and try seeing how this will work...
      Cheers
      Kim Frederik
        Ben Ritter
        Juju, may have to try that.
        Frederick, I'm using the Pro version and I did install the bonus pack.
        Thanks guys.
        Ben
          sepo
          Ben can you tell me do you have mac or windows version?
          • FrederikF Offline
            Frederik
            Could it be that your textures are placed in a folder or sub-folder (meaning the entire string) containing a non-standard letter..??
            (something outside the English alphabet...)
            I'm guessing here, since I can't grasp why you can't make this work... πŸ˜•
            Cheers
            Kim Frederik
              sepo
              Ben...could you call back to Podium forum....It will be solved much quicker over there.
                Ben Ritter
                Sepo, I'm running the windows version.
                Frederick, the textures is coming from the materials folder under the SU program folder. No unusual characters in the folder name.
                Thanks again guys. Ben
                  sepo
                  I would have prefered to deal with it on Podium forum but ok....tell me what you have in your Podium folder in plugins.
                  • FrederikF Offline
                    Frederik
                    OK... Then I'm out of ideas... 😐
                    I'm sure Sepo will be able to help you out here...
                    Perhaps you should take his advice and continue this on the Podium forum... πŸ˜‰
                    Cheers
                    Kim Frederik
                      sepo
                      solved...issue of permission to write the textures.
                        Ben Ritter
                        Thanks again everyone. Like Sepo indicated, problem solved.
                        Ben
                          mantis-1
                          I have the same problem, can someone explain how the problem was resolved.
                          Regards
                          Tim
                            sepo
                            Tim it about permission to write textures....go on the Podium forum....we have a tread about it.
                            • jujuJ Offline
                              juju
                              Hi Tim, welcome to the SCF!
                              See the post two places up from yours...
                              For the uninformed (i.e. those of you that don't check previous posts), this was using the Podium rendering software available for SU. A recent decision by management to throw all the toys into one basket and let you sift through it yourself resulted in the forum as it is now, somewhat overwhelming and disorganised.
                              • 2 / 2
