    3 Inch Cube - From 0.22 in. Thick Foam
    2 Posts 1 Posters 1.5k Views 1 Watching
    • G Offline
      GreenToaster
      Hello,
      Here's a tutorial I made that is for "total newbs" . . . we made these cubes (as posted previously on another SCF forum) out of 0.22 inch thick pink foam insulation. When finished properly, the cube measures 3 x 3 x 3.
      We make the foam cube, then follow up with the SkechUp cube. It's only the third full day of class this semester - eventually, they'll get it.
      I still have no idea where to post full size videos and I'm puzzled that Camtasia chopped off the last part of this video where I move the sides in place and copy to finish the cube. User error, I'm sure.
      Hope this helps someone.
      Happy Sketching,
      Brad
      πŸ˜„
      [flash=448,361:3c8wehpw]http://s103.photobucket.com/flash/player.swf?file=http://vid103.photobucket.com/albums/m157/ShermanPeabody/SU/3_inch_cube_01.flv[/flash:3c8wehpw]
      If you really want something you won't ever stop pursuing it.
      • G Offline
        GreenToaster
        . . . here's the revised version . . . same as original but now finished, showing how to move & copy the parts so the assembly is completed . . .
        [flash=448,361:3fr35mt9]http://i103.photobucket.com/player.swf?file=http://vid103.photobucket.com/albums/m157/ShermanPeabody/SU/3_inch_cube_02.flv[/flash:3fr35mt9]
        Hope this is helpful to someone.
