    Stamping components
    5 Posts 3 Posters 648 Views 3 Watching
    • G
      galbavy1
      hey guys.... I got a good question for you. I create a lanscape model by "pancaking" layers together. First I trace the jpg base, copy the faces then move that up a little and pushpull. Then I create a tin and move that up a little. I then copy the jpg on the z axis above the tin so I can put all the plant material on the 2d basemap. I want to drop all the plant material at the same time straight down and have each plant land perfectly on the tin. I can't get the drape or the stamp tool to do this. Is there any way to do this easily?
      • boofredlayB
        boofredlay
        You are looking for the Drop Ruby script.
        You can get it here for free:
        http://www.smustard.com/scripts/
        Here is another discussion on it too if that helps.
        404 Not Found
        (www.sketchucation.com)
        • GaieusG
          Yeah, the drape and stamp tools are to modify the terrain itself, not toput anything on it. That's the dropruby as Eric says.
          • G
            galbavy1
            Thanks guys... I feel like a tard when I can't find it in the search engine!
            • GaieusG
              Well, Eric linked the Smustard site to you already.Here is a more direct link to the plugin:
              http://www.smustard.com/script/Drop
