Construction face
Question
There is script to draw construction lines. And these line are not visible when show guides is turned off. So is it possible to make a construction face, such that when the show guides is turn off, the face becomes invisible?
Thanks for your time
Ken
Hi Ken,
well, to my best knowledge construction geometry consists of points and lines (infinite and finite).
I don't know what these ruby gurus might come up with (nowadays you dare not say NO to anything) but I don't think there is such a geometry as "construction face". You could use a simple face however put on a certain layer (where you could also put all your construction geometry as well) and control its visibility. Make sure to group that face though otherwse it will interact with other geometry.
Register LoginAdvertisement
