    Maxwell tutorial?
    5 Posts 5 Posters 2.8k Views 5 Watching
    • pugz1983P
      pugz1983
      Hi everybody,
      Anybody knows of a maxwell for sketchup tutorial. I managed to obtain maxwell, with the manual but this manual is way to complicated for me. And my english is very reasonable for someone from Holland. So please help.
      • R
        remus
        I just did a quick search and found this: http://www.pushpullbar.com/forums/showthread.php?t=6234 Not sure how good the results will be as i dont use maxwell.
        Theres also a load of good info in the maxwell forums, so its worth lurking around there.
        The only other thing to do is experiment. If youve got a bit of time to play around it is definetly the est way to learn how to do things.
        • I
          ilay7k
          search at http://think.maxwellrender.com/
          • StinkieS
            Stinkie
            Totally recommend this one! ๐Ÿ‘
            • A
              Ash.
              Check out this.
              http://www.pushpullbar.com/forums/showthread.php?t=6184
              You say you're from holland, so you wouldn't mind reading it in Dutch I guess, there's a Dutch and English version of my tutorial available at my forum, you need to register to read the Dutch version, not the English. ๐Ÿ˜„ enjoy.
              It explains most of the things to achieve a good result. The basic workflow. Some things might be changed since Maxwell 1.7 but not that much.
