    [Req] Toggle Units
    6 Posts 5 Posters 2.6k Views 5 Watching
    • CadFatherC
      CadFather
      i'm thinking (hoping) of a script that would help me toggle between feet and centimeters.
      that way i can assign a shortcut and toggle-view the dimension lines in the model in real time
      - scroll down for Matt's Toggle Units plugin -
      • Didier BurD
        Didier Bur
        Why don't you do it the usual way ???
        DB
        • R
          remus
          I think the idea is to be able to assign a shortcut key to it so you dont have to go through the whole window->model info thing each time you want to change them.
          • CadFatherC
            CadFather
            that's it...sometimes i have to design everything in feet - which is fine as long as i look at my own!
            instead one can just draw a dim line, push pull in centimeters and check it in feet - or viceversa..
            in fact, do all sorts things for those US projects.
            ..that is of course, until the planet 'unites'..
            is there ruby hope?
            • M
              Matt666
              Yep ! I will see tomorrow. It's late in France...
              Frenglish at its best !
              My scripts
              • J
                Jim
                I've split this thread at the attachments and moved it to it's own thread.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11745
