    How to make a hole-passage in a curved surface
    5 Posts 4 Posters 719 Views 4 Watching
    • S
      sushi
      I need Help!
      I have to make a hole in curved surface, the hole will be my passage, with an arc on top. Dunno how to make it because the surface is not straight but, as I said, it's curved.Thanx for the attention!!!
      • R
        remus
        Try the method in the tut, its pretty useful for other things as well.
        Hole through curved wall tut.skp
        • Jean LemireJ
          Jean Lemire
          Hi Remus, hi folks.
          Here is a trick I was once given on the old SU forum: When you save a multi scenes file, save it with the scene that you want to be active when you next open the file. Usually this will be the first scene. Otherwise, you give the punch by showing the final scene when the file opens.
          Just ideas.
          • S
            sushi
            You just made my day!!!! Thank you!
            • GaieusG
              Here is another one by Eric in the Tutorial Forum.
