    Slider joint
    5 Posts 4 Posters 710 Views 4 Watching
    • F
      Floppydisk35
      Hey people, I'm actually new to these forums.
      Anyways, I would like to do lift doors, and I have been working all morning to invent something to make them open, but after some search I've found that you actually need the slider tool to make the lift door open and close.
      My problem is, who do I use the slider? It's been like half an hour without any success!
      Thanks SU people! πŸ˜„
      • R
        remus
        by the sounds of it your talking about sketchy physics, this plugin allows you to place lots of different joints and states on geometry so they move in predictable ways when you run the in built physics engine. You can get this plugin from here (in the extensions sub forum, theres a forum dedicated to sketchyphysics.)
        However, for your application id recommend using the section cut method of animation. You should be able to find a thread explaning this in the tutorials forum.
        • GaieusG
          And here it is:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=19&t=633
          • R
            remus
            Cheers gai, i was feeling lazy last night.
              And don't miss this plug : Proper animation by Morisdov
