    Edit Shape's Dimensions
    2 Posts 2 Posters 410 Views 2 Watching
      silverhandprint
      How do I edit the dimensions to a 2D or 3D shape after I've drawn it. For example, I drew a 1 m × 3 m rectangle but now want to change it to into a 2 m × 3 m rectangle. How do I edit the width? Thanks!
        dylan
        Another option would be to select one side of the rectangle (line) then use the move tool to move the line the required distance. You can start to move then type the distance in the Value Conrol Box and press enter.
        Edit: Just realized James has explained this in his 2nd posted image above 😉
        http://dmdarchitecture.co.uk/
