    How to add texture on a plane into a script?
    5 Posts 3 Posters 759 Views 3 Watching
      sahi
      material = model.materials
      base = entities.add_face(pts)
      base.material = ????
        Jim
        From here: http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-drawingelement.html#material=
        material = drawingelement.material = material | "materialname" | color | "colorname"
        The right-hand-side can be a Material object, a material name (String), a Color object, or a color name (String)
        So...
        base.material = Sketchup;;Color.new(255, 0, 0) # Color
        base.material = 255 # Color
        base.material = 0xff # Color
        base.material = "red" # Color
        base.material = "#ff0000" # Color
        base.material = [1.0, 0.0, 0.0] # Color
        base.material = [255, 0, 0] # Color
        If you want to use a Material that is already in the Model, you can get it through the Materials object.
        mat = Sketchup.active_model.materials["Material Name"]
        base.material = mat
        If you want to create a new Material from a image file:
        mat = Sketchup.active_model.materials.add "New Material Name"
        mat.texture = "c;\\path\\to\\texture\\image.png"
        base.material = mat
        Note this is from the API documentation and may contain inaccuracies.
          sahi
          base.material = mat
          Thank you! Thank you! Thank you!
            sahi
            how to place texture on a center?
            position_material  ????
              RickW
              Need to use a UVHelper - set the middle coordinate of the texture to be the same as the middle coordinate of the face (is one way).
              RickW
              www.smustard.com
