    Proper_animation.rb ,some questions
    45 Posts 14 Posters 9.5k Views 14 Watching
    • MALAISEM Offline
      MALAISE
      Hello Gentlemen
      I've tested more the plugin proper-animation from our friend Morisdov
      Great indeed, if you need to explain sequential tasks ( robotic...).
      I would suggest some enhancements:
      If you look at the joined file, you'll see that rotations are not really
      centered, giving some strange visual effects ( the groups seem not rotate along
      the same centre) Of course, if several movements are done during the transition
      from one scene to the next, we "smooth" that default.
      Another effect, may be easily hidden, appears when using loop animation. The transition between the last and the first scene, let us see jump of group to
      original positions when they are not involve immediately.
      Maybe theses remarks could help.
      How easy would it be when copying and paste scenes for looping movements could be done, but that's another subject. 😕
      Thank you.
      MALAISE 😄
      use of proper-animation test
        an another funny thing is that the shadows arrive after the movement 😉
          I don't have the plugin on this computer but I've seen (and asked about) the issue with rotations. It just occurred to me to wonder; what if you make the rotating part a component instead of a group and place its axis so the origin is at the center of rotation. I haven't tried this but maybe that's the fix.
          • N Offline
            N Lindenthal
            How can I get the »Transformation« menue item in right mouse click on mac. I miss it.
            • MALAISEM Offline
              MALAISE
              Very clever advice Dave. 👍 👍
              I try it as soon as possible.
              Effectively, I did notice the shadow's delay 👍 Pilou 😉
              About transformation, it's on mouse right click when you select a group
              in order to store its new position ( Guck mal in Deutscher Abteilung, mein Post )
              N Lindenthal 😄
              Thanks for PM, Guys
              MALAISE
              • N Offline
                N Lindenthal
                @malaise said:
                on mouse right click when you select a group in order to store its new position
                Hello, Malaise,
                I did never find the »Transformation« item in right mouse click. New file, new circle, pull, mark all, make a group, mark group, right mouse click:
                I miss the »Transformation« in right mouse click
                  Shotster
                  Interesting you should mention this. A couple days ago I did just that in an effort to get my paper folding animation to work. (Right click and choose play.)
                  [flash=200,193:21jtvhjy]http://www.adeptool.com/anim/PaperFold.swf[/flash:21jtvhjy]
                  -Steve
                  • N Offline
                    N Lindenthal
                    maybe your plug is not installed?
                    If I write in ruby console:
                    load "proper_animation.rb"
                    I get »true«, so the plug is installed.
                    But is there anyone on mac, who can show, that the plug is running?
                      @ N Lindenthal so maybe your plug is not installed?
                      That you must see on the Right Click (on Transformations) 😉
                      • MALAISEM Offline
                        MALAISE
                        N Lidenthal , Unfortunaly, I left Mac technology for a long while.
                        Can you read animated files ( one of mine for instance )? then try to modify it
                        just in order to see if it's not Mac-dependant ❓ ❓
                        Hi Shotster
                        What kind of software do you use to display this small picture?
                        MALAISE 😄 😄
                        • N Offline
                          N Lindenthal
                          @Malaise
                          I can watch animated files on mac, and I tried to modify them. But to give them a new transformation, was unsucessfull, because in right mouse click there is no transformation.
                          In context menu (right mouse click on marked objects) there are several textlines and several bounding lines. If I take the proper_animation.rb-script away from plugins folder and start SU again, the context menu has one bounding line less. Under the textlines there are 2 bounding lines. If proper_animation is installed, there are 3 bounding lines.
                          It seems, that between the bounding lines should exist a text line from one ruby script. So what ruby script also does not apear there?
                          • MALAISEM Offline
                            MALAISE
                            Hallo N Lindenthal
                             There is probably something wrong written in the rb.file. Please send it me
                            and I'll test it on my PC ( not Mac tut mir Leit ). Then we may ask his author some improvement.
                            Tschüss
                            MALAISE
                            • N Offline
                              N Lindenthal
                              Malaise, you got my .rb-file over PM?
                                Shotster
                                It's actually an embedded Flash animation. You should get a contextual menu when you right click on it. Select "Play" to view the animation.
                                -Steve
                                  and when you right click on the image you can see the name of the prog 😉
                                  • MALAISEM Offline
                                    MALAISE
                                    Hello Gents
                                     The transformation option will appear only if a group or component is selected
                                    whatever the observer view is ON or OFF. I mean you click on group to reach positions ( set or get ..)
                                    The use of stop animation observer stores the new view after all changes.
                                    Start animation observer enables the show (scenes 1 then 2 .....)
                                    It seems to be simple but not so obvious.
                                    You have to select all the groups or components activated involved in the scene, after any modification of one or more groups, before setting a new position. If you jump this stage you may get strange results.
                                    I have one question : ( Mainly for the plugin's father 😉 )
                                    All movements are done within the same time. I mean a long displacement or a
                                    short rotation require 1 second..( for instance )
                                    Could it be possible later to modify this "time" parameter ?
                                    Thanks for attention
                                    MALAISE 😄 😄
                                      morisdov
                                      Hello Guys,
                                      1. When rotating an object, Setting the axis so the origin is at the center of rotation - as suggested by DaveR - is probably the eaysiest way to control the "center" of the object you are animating/rotating.
                                      2. I dont have access to a mac machine so all my ruby programming and tests are done on windows only.
                                      3. I read some post by RickW that Each scene/page can get its own "transition" time - so i can probably do it - but, we will never compete with true "timeline" based animations like 3DSMax and Maya, you can use few scenes to simulate a single long leg of an animation part.
                                      4. When an object is selected for "animation" - in "Windows->Preferences->Shortcuts" you may define "Position X" shortcut keys if you want.
                                      5. I am traying to keep this plugin "simple" by adding only "must" features if we have to, maybe later we will add more "nice to have" settings.
                                      Keep on the good work, Moris
                                      • MALAISEM Offline
                                        MALAISE
                                        Hallo Morisdov
                                        Nice to read you again.
                                        Hereby I send another file using the plugin you've made.
                                        Just see how fast is the boat crossing the gate ( what 's the name in English ?)
                                        ( even if I modify animation setting ) but I will survive 😆
                                        Thanks you once more time.
                                        MALAISE 😄
                                        boat and water gates ?
                                          me3mar
                                          is it possible to render such an animation using proper_animation.rb and vray ?
                                          • MALAISEM Offline
                                            MALAISE
                                            Hello Guys
                                            I see, you've downloaded the file. About Vray, i'm not experienced.
                                            Maybe one of us have already opened the way ??
                                            MALAISE 👍
                                            • 1 / 3
