Proper_animation.rb ,some questions
Hello Gentlemen
I've tested more the plugin proper-animation from our friend Morisdov
Great indeed, if you need to explain sequential tasks ( robotic...).
I would suggest some enhancements:If you look at the joined file, you'll see that rotations are not really
centered, giving some strange visual effects ( the groups seem not rotate along
the same centre) Of course, if several movements are done during the transition
from one scene to the next, we "smooth" that default.Another effect, may be easily hidden, appears when using loop animation. The transition between the last and the first scene, let us see jump of group to
original positions when they are not involve immediately.Maybe theses remarks could help.
How easy would it be when copying and paste scenes for looping movements could be done, but that's another subject.
Thank you.
MALAISE
an another funny thing is that the shadows arrive after the movement
I don't have the plugin on this computer but I've seen (and asked about) the issue with rotations. It just occurred to me to wonder; what if you make the rotating part a component instead of a group and place its axis so the origin is at the center of rotation. I haven't tried this but maybe that's the fix.
How can I get the »Transformation« menue item in right mouse click on mac. I miss it.
Very clever advice Dave.
I try it as soon as possible.
Effectively, I did notice the shadow's delay
Pilou
About transformation, it's on mouse right click when you select a group
in order to store its new position ( Guck mal in Deutscher Abteilung, mein Post )
N LindenthalThanks for PM, Guys
MALAISE -
@malaise said:
on mouse right click when you select a group in order to store its new position
…Hello, Malaise,
I did never find the »Transformation« item in right mouse click. New file, new circle, pull, mark all, make a group, mark group, right mouse click:
Interesting you should mention this. A couple days ago I did just that in an effort to get my paper folding animation to work. (Right click and choose play.)
[flash=200,193:21jtvhjy]http://www.adeptool.com/anim/PaperFold.swf[/flash:21jtvhjy]
-Steve
maybe your plug is not installed?If I write in ruby console:
load "proper_animation.rb"
I get »true«, so the plug is installed.
But is there anyone on mac, who can show, that the plug is running?
N Lidenthal , Unfortunaly, I left Mac technology for a long while.
Can you read animated files ( one of mine for instance )? then try to modify it
just in order to see if it's not Mac-dependantHi Shotster
What kind of software do you use to display this small picture?MALAISE
@Malaise
I can watch animated files on mac, and I tried to modify them. But to give them a new transformation, was unsucessfull, because in right mouse click there is no transformation.In context menu (right mouse click on marked objects) there are several textlines and several bounding lines. If I take the proper_animation.rb-script away from plugins folder and start SU again, the context menu has one bounding line less. Under the textlines there are 2 bounding lines. If proper_animation is installed, there are 3 bounding lines.
It seems, that between the bounding lines should exist a text line from one ruby script. So what ruby script also does not apear there?
Hallo N Lindenthal
There is probably something wrong written in the rb.file. Please send it me and I'll test it on my PC ( not Mac tut mir Leit ). Then we may ask his author some improvement.
Tschüss
MALAISE -
Malaise, you got my .rb-file over PM?
It's actually an embedded Flash animation. You should get a contextual menu when you right click on it. Select "Play" to view the animation.
-Steve
and when you right click on the image you can see the name of the prog
Hello Gents
The transformation option will appear only if a group or component is selected
whatever the observer view is ON or OFF. I mean you click on group to reach positions ( set or get ..)
The use of stop animation observer stores the new view after all changes.
Start animation observer enables the show (scenes 1 then 2 .....)It seems to be simple but not so obvious.
You have to select all the groups or components activated involved in the scene, after any modification of one or more groups, before setting a new position. If you jump this stage you may get strange results.
I have one question : ( Mainly for the plugin's father
All movements are done within the same time. I mean a long displacement or a
short rotation require 1 second..( for instance )Could it be possible later to modify this "time" parameter ?
Thanks for attention
MALAISE
Hello Guys,
- When rotating an object, Setting the axis so the origin is at the center of rotation - as suggested by DaveR - is probably the eaysiest way to control the "center" of the object you are animating/rotating.
- I dont have access to a mac machine so all my ruby programming and tests are done on windows only.
- I read some post by RickW that Each scene/page can get its own "transition" time - so i can probably do it - but, we will never compete with true "timeline" based animations like 3DSMax and Maya, you can use few scenes to simulate a single long leg of an animation part.
- When an object is selected for "animation" - in "Windows->Preferences->Shortcuts" you may define "Position X" shortcut keys if you want.
- I am traying to keep this plugin "simple" by adding only "must" features if we have to, maybe later we will add more "nice to have" settings.
Keep on the good work, Moris
Hallo Morisdov
Nice to read you again.
Hereby I send another file using the plugin you've made.Just see how fast is the boat crossing the gate ( what 's the name in English ?)
( even if I modify animation setting ) but I will survive
Thanks you once more time.MALAISE
is it possible to render such an animation using proper_animation.rb and vray ?
Hello Guys
I see, you've downloaded the file. About Vray, i'm not experienced.
Maybe one of us have already opened the way ??MALAISE
