Viewport question
Not sure if this is the right spot for this question, but is it possible to some how have a quad viewport? So while you're modelling having the top/side/front/ and 3/4 view of your model?
thanks
gaganraj,
You're correct, this isn't the best spot!
But to answer your question, SKUP doesn't have the viewport functions of AutoCAD, however, you can use the scenes function to flick between different views.
In Window/Model Info menu, untick the "enable Scenes transistions" option in the animation section.
Then in the Scenses tab, untick all the options apart from Camera location, then create a scene, move your position & create another.
You can then start a command & flick between the views mid-command - try doing that in ACAD!
Register LoginAdvertisement
