    Vase
    16 Posts 5 Posters 1.6k Views 5 Watching
      justry
      Hey everyone,
      This is a vase I made in sketchup, using the follow me tool and sketchyFFD, which is an awesome plugin by the way.
      I was reluctant to post this at the beginning, seeing all the awesome stuff posted here, but then I thought I'd just post it anyway.
      Hope anyone likes it πŸ˜„
        Hi Justry,
        Here I am for instance who likes it! πŸ˜„
        One comment though: you seem to have placed the vase (great model BTW) on a floor texture. Now that's truely out of scale! This vase seems to be like 10 metres high! πŸ˜„
        • soloS Offline
          solo
          I like it too, I kinda agree with Gaieus but think the floor shoud be scaled up πŸ˜„
          What render program did you use?
          http://www.solos-art.com
            justry
            Thanks guys, this is so encouraging πŸ˜„ .
            I used kerkythea for texturing and rendering. The vase is actually 1.15 meters high (guess it's more of an urn then πŸ’š ). But I didn't modify the floor texture, it was a readymade one and I just applied it. I think that's how it was meant to be, cause when I previewed it in the kerkythea material editor, it was small on the preview model too.
              OK, llet's say its a woven material (like rat(t)an or something) on the table πŸ˜„
                justry
                Yeah that's gotta be it πŸ’š .
                • FrederikF Offline
                  Frederik
                  @justry said:
                  But I didn't modify the floor texture, it was a readymade one and I just applied it. I think that's how it was meant to be...
                  Yes and no... The material is ready for use, but depending on the material you've applied in SU and the scale of it, you might also need to re-scale the material in KT before you render your scene... πŸ˜‰
                  Nice model BTW... πŸ˜„
                  Cheers
                  Kim Frederik
                    justry
                    Thanks again for your really encouraging comments β˜€ .
                    But I didn't have any material applied in sketchup. As a matter of fact I didn't even make that floor in sketchup!! It's a kerkythea infinite plane. But I'm sure the texture's meant to be that way. It looked like that even in the preview. It's one of the material libraries in the KT repository. It was called "floors". I think it was by Darren Sintra.
                    • FrederikF Offline
                      Frederik
                      I believe the floor material you've used is taken from the (Lis) Wooden Floors.... πŸ˜‰
                      Please believe me when I say that you do need to re-scale the material... πŸ˜‰
                      To make it easier for you before you start the render, in KT press the "V" on your keyboard to toggle from the standard "Wireframe" to "Solid"...
                      In the Scene Tree View, right-click the material where you've applied the wooden floor and select "Edit material" in the sub-menu...
                      You will see that it's a layered material...
                      1.) Click the "#0" layer...
                      2.) Now click the word "Diffuse"...
                      3.) Click the bit-map in the "Texture Editor" box...
                      4.) In the "Coordinates" you can change the X and Y scale...
                      Try setting it to "0,100" (in order to scale it up)
                      5.) Remember to repeat the above steps to the texture applied in the "Bump Mapping" channel... πŸ˜‰
                      Hope this can help you further... πŸ˜‰
                      P.S. I'm just trying to help you, but if you don't believe what I'm saying, by all means, please disregard my post... πŸ˜‰
                      Cheers
                      Kim Frederik
                        justry
                        Oh ok. I'll try that right now!
                        Thanks!
                          justry
                          Yeah! It looks much better now! I also scaled down the vase to help.
                          That's weird though... I thought that if it's like this by default then that's what it's supposed to look like. Is this due to some kind of miscalculation by the person who made the material or something?
                          • soloS Offline
                            solo
                            Looks much, much better ...however.... the bump on the parquet tiles is reversed.
                            • FrederikF Offline
                              Frederik
                              I agree with Solo... The bump map seem to be reversed... 😐
                              But again it's pretty easy to fix... πŸ˜‰
                              Cheers
                              Kim Frederik
                                justry
                                Fixed it. I had spotted that option and guessed that it was the answer πŸ’š .
                                Still, why is this happening? Is the problem with the material library itself or with kerkythea or what?
                                • FrederikF Offline
                                  Frederik
                                  It's the material... 😐
                                  I assume that the person making this library wasn't taking care of this...
                                  Cheers
                                  Kim Frederik
                                    justry
                                    Hmm. Oh well...
                                    Thanks a lot for your help. I'm liking kerkythea more and more, it's so easy to use.
                                    Not that I tried anything else πŸ’š , but I still like it πŸ˜‰ .
