    Recognising Sketchup
    5 Posts 3 Posters 871 Views 3 Watching
    • chrisglasierC Offline
      chrisglasier
      I am trying to get a web dialog to recognise it has been opened by a sketchup plugin. Is there some standard Ruby like window.opener in Javascript. (The html file in the web dialog can be opened and used with other applications provided the Sketchup switch = 0).
      Any guidance gratefully received ... Thanks
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        RickW
        Sorry, I'm not sure what you are trying to do.
        @dialog = UI.webDialog.new
        @dialog.show()
        @dialog.visible? # returns true if the dialog is visible
        This will tell ruby that the dialog is open, but I don't think that's what you were asking. What do you need to accomplish?
        EDIT: After a few more readings, I think I may have figured it out 😄 You could use @dialog.execute_script(javascript_goes_here) that could set a js variable to say the html was opened from SketchUp.
        RickW
        www.smustard.com
          chrisglasier
          Many thanks ... apologises for the many readings!
          I tried a function call as shown here:
          #Ruby
          @dlg = UI;;WebDialog.new("Nameset", false,"",300, 205,0,0,false)
          	subDir = "D;/Nameset3/"
          	fileName = "Nameset3 machine.htm"
          @dlg.set_file File.join(File.dirname(__FILE__), subDir+fileName)
          @dlg.execute_script("startSketchup()")
          //javascript
          function startSketchup(){
          sketchup=1
          productsRun()}    //picks up and positions skp components
          The dlg.execute_script works fine from the Ruby console but not directly. Obviously I am missing something - but what?? I tried a add_action_callback but that causes much aggro with non-Sketchup use, and I quickly gave up trying to get one to work.
          Further advice much appreciated.
          Chris
            CPhillips
            This is kinda a hack, but in javascript window.external will throw a "not implimented" exception under Sketchup but not under IE or Firefox.
            You could catch that exception and set a flag.
              chrisglasier
              Thanks for the responses. I have persevered with the dialog.execute_script because this seems right and proper, but I think at least for the moment I have to fall back on the exception business - probably try ... catch rather than window.external as I use that a lot during development stages.
              Thanks again.
              Chris
