    Recognising Sketchup
    5 Posts 3 Posters 734 Views 3 Watching
    • chrisglasierC Offline
      chrisglasier
      I am trying to get a web dialog to recognise it has been opened by a sketchup plugin. Is there some standard Ruby like window.opener in Javascript. (The html file in the web dialog can be opened and used with other applications provided the Sketchup switch = 0).
      Any guidance gratefully received ... Thanks
        RickW
        Sorry, I'm not sure what you are trying to do.
        @dialog = UI.webDialog.new
        @dialog.show()
        @dialog.visible? # returns true if the dialog is visible
        This will tell ruby that the dialog is open, but I don't think that's what you were asking. What do you need to accomplish?
        EDIT: After a few more readings, I think I may have figured it out 😄 You could use @dialog.execute_script(javascript_goes_here) that could set a js variable to say the html was opened from SketchUp.
        RickW
        [www.smustard.com](http://www.smustard.com)
          chrisglasier
          Many thanks ... apologises for the many readings!
          I tried a function call as shown here:
          #Ruby
          @dlg = UI;;WebDialog.new("Nameset", false,"",300, 205,0,0,false)
          	subDir = "D;/Nameset3/"
          	fileName = "Nameset3 machine.htm"
          @dlg.set_file File.join(File.dirname(__FILE__), subDir+fileName)
          @dlg.execute_script("startSketchup()")
          //javascript
          function startSketchup(){
          sketchup=1
          productsRun()}    //picks up and positions skp components
          The dlg.execute_script works fine from the Ruby console but not directly. Obviously I am missing something - but what?? I tried a add_action_callback but that causes much aggro with non-Sketchup use, and I quickly gave up trying to get one to work.
          Further advice much appreciated.
            CPhillips
            This is kinda a hack, but in javascript window.external will throw a "not implimented" exception under Sketchup but not under IE or Firefox.
            You could catch that exception and set a flag.
              chrisglasier
              Thanks for the responses. I have persevered with the dialog.execute_script because this seems right and proper, but I think at least for the moment I have to fall back on the exception business - probably try ... catch rather than window.external as I use that a lot during development stages.
              Thanks again.
