    Comma doesn't work when entering precise values...
    2 Posts 2 Posters 572 Views 2 Watching
    • A
      atleee
      Hi!
      When I try to use comma as a separator between the axis when entering precise values sketchup reads it as a decimal point instead. (Example: If I enter 50,50 while making a rectangle, it only sets one edge to 50.5 cm and leaves the other one untouched) This may be because in Norway we use commas, not points as decimal separators. I tried to switch to US input in the keyboard settings but it didn't help. Any ideas anyone?
      • GaieusG
        Your system defines what separators you have to use. If your system is not English, you have to use a comma as a de4cimal separator and a semicolon ; as a separator for the different sides.
        It may be a bit painful because on my keyboard, to access the semicolon, I have to press AltGr (or Alt+Ctrl) and Ctrl for instance is a modification key in a couple of cases. The same goes with the <> or [] brakets therefore I cannot move anything to absolute co-ordinates for instance.
