    Fry render v1 released
    36 Posts 12 Posters 6.5k Views 12 Watching
    • K Offline
      kwistenbiebel
      That's strange. Are you sure you have version 1 ?
      • soloS Offline
        solo
        The latest one off the website (demo)
        http://www.solos-art.com
        • I Offline
          ilay7k
          Try to activate toolbar from plug-ins menu, fry-menu >> show/hide fry toolbar 😉
          • soloS Offline
            solo
            I do not have the fry-menu option in the plugins drop down menu.
            • I Offline
              ilay7k
              strange, i have
              http://img389.imageshack.us/img389/3467/fr1gh0.th.jpg
              Asian bridge by Sean Headrick
              you install via this?...
              1. fry_su will only work on the PRO version of SketchUp
              2. Given the contents of the proper zip (su_5/fry_su.zip or su_6/fry_su.zip, depending on which version you're using):
                - copy fry_su.dll file to <SketchUp folder>\Exporters
                - copy fry_su_loader_SU#.rbs and Win32API.so files to <SketchUp folder>\plugins
              3. Start SketchUp, if everything is ok, you should see a FRYRENDER entry under Plugins menu section
              • K Offline
                kwistenbiebel
                Solo, I can't give you an answer to your problem, besides checking your folders to see if all was installed well (the .dll files as Ilay said etc...).
                Feversoft should open up their forum for the demo users. I asked them before...maybe I should askit again now the final version is out.
                • plot-parisP Offline
                  plot-paris
                  thank you very much, kwistenbiebel. with that detailed explanation of the worklfow you made me curious. I liked the maxwell interface in principal; but some things were a bit clunky. fry seems to be one step ahead in terms of interface/workflow...
                  • K Offline
                    kwistenbiebel
                    Indeed, the nice thing is that you can open all these panels from within Sketchup.
                    No need to export your file first to a Studio to do editing there.
                    By the way, the Fry manual has just been released.
                      remus
                      Available form here: http://tutorials.fryrender.com/#manual
                        silver_shadow
                        mine is doing the same as solos one. all works fine, when checking it in skp, nothing works.
                        do you mind sharing those fryrender sketchup plugins. Its no where else to find on any website than one place and it does not really seems to work. I really wanna try this, emailed fryrenders website, no reply, registered to go into fryrenders forums, no permissions to post anything..so im reallly really stuck. please please help 🤓
                        • H Offline
                          huyvuvn
                          anyone have fryrender plugin of Sketchup . Plz share to me , many thanks 😉
                          happiness on the way, not in the destination.
                          • I Offline
                            ilay7k
                            try to download from official site.
                            plug-n is in install package.
                            that's all.
                              silver_shadow
                              the plugins you can find is on your hard drive, came with the program, found that after i got some plugins is downloaded
                              C:\feversoft\fryrender\plugins32\fry_su\su_6
                              hope it helps
                                ScottPara
                                I am having the same issue and do not see fryrender in the plugins drop down either. Has anyone found a fix for this?
                                Scott
                                Love the fact that some HATE my avatar.....
                                • pugz1983P Offline
                                  pugz1983
                                  Hi Everybody,
                                  Still looking for a good Fryrender Sketchup tutorial. The screenshot did help me a lot so far, but still some issues. Sometimes materials wil render the default checkerd map ( Orange/black ) and not sketchup stone material. I also want to try displacement with some grass in Fryrender. Can enybody help me. Tips and tricks for Fryrender to Sketchup workflow would be awesome.
                                  Greetz from holland.
                                    rparrinha
                                    Hi.
                                    Has anyone found a solution for the problem Solo mentioned earlier?
                                    I've got Win XP 64 and the plugin doesn't work with the 64 bit Demo.
                                    There isn't any menu or toolbar of Fryrender in Sketchup. But it doesn't give an error.
                                    • 2 / 2
