    Components Update ? @TIG
    3 Posts 2 Posters 487 Views 2 Watching
    • Didier BurD Offline
      Didier Bur
      i want to have an "compos update" function of all the components of the model.
      This seems not to work:
      defs=Sketchup.active_model.definitions
      defs.each { |comp| defs.load  comp.path } #assuming comp.path != nil
      This doesn't return any error BUT the components are not updated (same geometry). What's wrong in this code ?
      After reading XrefManager script, it seems that refreshing an Xref is done by adding a new definition to the model from a SKP file, then make the old component "obsolete", and re-inserting every instance of the former component. I hope there's another way to do this, as simple as doing it manually in the compos browser... ❓
      Regards,
      DB
        Didier
        My Xref Manager is somewhat out of date since I could now use 'import' to do this much easier - but don't tell anyone !
        I must get around to re-doing it one day - so much to do, so little time !
        Why not try import rather than load ?
          Didier Bur
          {|e|model.import(comp.path)}
          πŸ’­ πŸ’­ πŸ’­ as always, thanx TIG
          DB
