    [Plugin] Memory Copy (xformclone.rb)
    44 Posts 26 Posters 61.4k Views 26 Watching
      The latest version of this script is in RBZ format in the PluginStore:
      https://sketchucation.com/pluginstore?pln=xformclone
      Alternatively you can add any lone RB into your Plugins folder 'manually'...
      It's called 'xformclone.rb' in this case.
      Lone scripts like this are 'unsigned' and therefore newer versions of SketchUp must have their Extension Manager Loading policy set to Unrestricted.
      Since it's an old script I am uncertain about its compatibility with newer versions...
        rv1974
        TIG, this tool has big problems with precision (rotation is OK, fails at moving)
        I tried your Grow.rb- works perfectly. So maybe it's possible to update this script inserting some portions of Grow.rb please? Thanks in advance.
        P.S. Please see attached: try to make >30 copies upward. The script just can't put components exactly on Cpoints
        iii.skp
        • K Offline
          Kondybas
          The most indispensable plugin for my project. All other have alternatives but not that.
          • F Offline
            FlorinAp
            There is another one from Eneroth, and i think maybe two more (one may be Tax Engineering, plus another one)
            • 3 / 3
