    Kerkythea...am I dreaming?
    extensions
    2 Posts 2 Posters 1.1k Views 2 Watching
    • A
      architeriffic
      So is Kerkythea as good as it sounds, the images that I see compare with some of the best Maya renders I've seen.
      Is there a downside? who out there is using it and can you comment on its usability... I learned on Maya and know how difficult it can be to get a good render. I have also used Podium and think it does ok interiors and have just been messing around with IDX Renditioner which I find to be lacking seriously.
      • FrederikF
        Frederik
        Although I'm part of the KT Team and people thereby might disqualify me for replying here, I give it a go anyway... πŸ˜„
        To answer your first question:
        No you're not dreaming... KT is a really good and stable render... πŸ˜‰
        And perhaps most impressive... One of the few render applications, where you can take advantage of both biased and unbiased render methods...
        But since it's free, you can easily test and check it out yourself and be your own judge...!
        Some users find KT difficult to use, while others adapt the techniques very quickly... πŸ˜‰
        The same can be said about any other render application...
        I recommend that you download and read the Getting Started tutorial, which will guide you through the application enabling you to get started...
        In our Tutorials section of our Download area, you can find many useful tutorials... Even some of the older tutorials might help you crasp things better... πŸ˜‰
        As a final word regarding how to make a good render, I will take a very wise quote by Pete (aka Solo):
        ...you must realize having the tools does not make one a carpenter, meaning that there is a level of artistic talent and desire needed in order to set up a scene, composition, lighting, texturing, modeling, and so forth that requires one to have a genuine interest and find much enjoyment in what one is doing in order to succeed...
        I hope this can help you further...!? πŸ˜‰
        Cheers
        Kim Frederik
