Push/pull a cad file
When you import a CAD file is there any way to extrude (push/pull tool) it without having to trace over the cad file first?
If you go over to smustard, theres a ruby script called makefaces. It will fill in all the faces on the file so you can push/pull them.
Register LoginAdvertisement
