    SU installing problems
    9 Posts 3 Posters 1.3k Views 3 Watching
    • ely862meE
      ely862me
      Hi guys!
      Anyone knows how can i fix this!?
      Earlyer installation is completely removed from my pc.
      Elisei (sketchupper)
      Come and See EliseiDesign
      • GaieusG
        No matter you uninstalled the other version, it must have left some registry entries in you Windows system. You should find it somehow in the regedit file and delete them (something I wouldn't really like to give advices about since I'm not a windows expert myself).
        • ely862meE
          ely862me
          i ve searched something there but no result
          there must be a way and i ll find it
          Thx for answering back!
          It will be any problem if i delete all registrys of Sketchup?
          Elisei
          • GaieusG
            There shouldn't once the program is uninstalled but ask somebody who knows it better. Also teher are a couple of nifty registry cleaners out there that may be able to do the job for you. Also make sure that after uninstalling the program, you remove everything from the Program Files folder (Google/Google SU 6)
            • ely862meE
              ely862me
              i deleted all google registry...same problem
              still searching for a way to fix it
              without sketchup i m busted πŸ˜„
              • Alan FraserA
                Alan Fraser
                Elisei,
                There are some Registry entries under HKEY_LOCAL_MACHINE/SOFTWARE/GOOGLE, but all the serious stuff is in various sub-folders of HKEY_CURRENT_USER/SOFTWARE/GOOGLE/SketchUp6
                It's usually not a good idea to meddle with this stuff...especially as much of it can be set via Preferences, but it does occasionally have its uses...like when a dialog box disappears off the screen. You can go to the appropriate Snappy folder and reset its coordinates to bring it back from Outer Space.
                Glad you sorted out the install problem.
                3D Figures
                • ely862meE
                  ely862me
                  well yes i know where de registrys are,and i deleted those from the sketchup all but didn't worked
                  but that*s ok,now it seems to be working !
                  thx for all the advices πŸ˜‰
                  Elisei
                  • ely862meE
                    ely862me
                    I uninstalled the Sketchup because of the graphic driver wich i updated a while ago.Since then when i was working in SU the screen was flashing and sometimes freeze in pieces,the lines were wider,when selecting some tools the screen was like a haotic animation
                    hm all that because of my nvidia gforce 8600 GT (1024mb)driver update....what was wrong?
                    right now i ve reinstaled the original driver and all is fine!!
                    Computers...but i never gave up!
                    Elisei
                    • ely862meE
                      ely862me
                      ok! i ve just fixed it;i should think better
                      i just download the latest version and installed it
                      but still wondering where are they putting those registry?ΒΏ
                      deeply hidden
                      THX!
                      Elisei
