    Hidden Printer Dialogs with Vista
    1 Posts 1 Posters 923 Views 1 Watching
    • daikuD
      daiku
      I thought surely other folks would be having this same problem, but I can't find other posts about it, so here I am. I recently upgraded to 64-bit vista (from XP), and downloaded the latest SU. Printer control dialogs get hidden behind the SU window. Here's the sequence: I select print from the file menu and get the main print dialog. I then select properties (to change the page size, for example). The properties dialog comes up, and I make my change and press OK. The properties dialog disappears, of course, but so does the main print dialog! But it really didn't go away. If I click anywhere in the SU window, it comes back! Has anyone else seen this or reported it? Thanks, CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
