    Exporting dwg
    3 Posts 3 Posters 859 Views 3 Watching
    • C
      cjlopez4
      Is there a way to change the default export units from decimal to architectural?
      C
      • R
        remus
        Theres probably a better way of doing it, but you can go window->preferences->template and choose a starting template in your units of choice.
        Once youve done that, select all your geometry and copy it across in to a new file, this should then export in the correct units.
        • AnssiA
          Anssi
          The DWG export uses exactly the same units you are using to model with. The units can be changed on the fly from the Window>Model Info>Units pane. No need to export, copy over etc. Your model and the "real world" stay in sync.
          Anssi
