    How does one create a TIN model in sketchup?
    5 Posts 4 Posters 1.3k Views 4 Watching
    • C
      cloverleaf
      hello all,
      i found several post regarding creating a TIN model, does anybody know what is TIN model and how can i create one?
      thanks
      • C
        cloverleaf
        james thanks!!!!! 😍
        • R
          ridix
          TIN stands for Triangulated Irregular Network; 3D description of a surface using triangular polygons. There is good description here:
          Error 404 - Not Found
          (www.ian-ko.com)
          To make it, just put diagonal line on quad surface. Than the apex away from this diagonal line can be moved out of plane.
            Looks these posts of F Bartels some videos about tins and crazy images about use of them!
            • R
              remus
              If youve got the subd and smooth plugin, you can get a similar effect (a model that is very triangulated) simply using the subdivide feature a few times.
