    Follow me error
    4 Posts 3 Posters 753 Views 3 Watching
    • romboutR Offline
      rombout
      hi there,
      im kinda new to google sketchup. Ive watchen a lot of tutorials about SU and how it works etc.
      I got this problem. If i draw a rectangle and pull in to orb. Than a draw a arc on one of the sides and than select the upper face and than go to the follow me tool. it has to make all rounded edges. ok... but there is always a small gab when i do this see the attachments. cant solve this one...the arch which will used by the follow me tool
      the small gab which apears every time
      • ely862meE Offline
        ely862me
        post a sketchup file if u want
        Elisei (sketchupper)
        Come and See EliseiDesign
          remus
          Might i ask what sort of size the model is? If its quite small, like in the mm, SU can be a bit fussy about making faces. If this is the case its easily solved by scaling your model up 100 times, doing te follow me and hen scaling it back down again.
          • romboutR Offline
            rombout
            remus thanx for the tip... indeed i was working in mm. but it wasnt that small. i was trying to make a wooden table which has plywood tiles of 500mm x 100mm. but i scaled it and than made the arc without the cut thanks again.
            ps im working on a imac 24" with leopard. i got this mac on my work just a couple weeks, im not really sure i like it. native im a graphic designer and used to work on amc a couple years a ago. I loved the mac always for it steady system, but this system sucks a bit!!! SU suddenly quits aswell with other programs. i read that tiger is much more stable πŸ’š
