    Overlay text misplaced in image exports
    3 Posts 2 Posters 1.1k Views 2 Watching
    • J
      Jackson
      When I export a series of scenes as a jpg animation some overlaid text goes slightly out of alignment- see the "C" on the section line in the exported image compared to the screenshot. While we're at it, there's a funny little bug with overlaid text whereby when you copy some overlaid text horizontally it moves up slightly, depending on the font size. If you continue copy/moving instances of the text across the screen they end up arrayed slightly diagonally.Text Export Bug Screenshot.jpgText Export Bug Export.jpg
      Jackson
      • L
        lewiswadsworth
        Does it happen if you export a single 2D image as opposed to a series? And have you tried varying the font?
        col sporcar si trova
        • J
          Jackson
          Ughhh, I just re-read that and realised it wasn't very clear, I edited my first line. It only happens (thankfully) when you export jpg animations, not when you export 2d graphics. I use this method so I can batch export perspectives, elevations, sections and plans from skp models which can take up to 30 minutes in total.
          I'm not sure if font affects it (I just used Arial), but I suspect the two issues I mentioned are connected as it is the largest font (the "C") which moves out of alignment the most and the "horizontal copy" bug becomes more pronounced the larger the font size.
          Jackson
