    Trying to Make a Car . . .
    6 Posts 3 Posters 826 Views 3 Watching
    • D
      DaRkM
      I am trying to make a Nissan Skyline using a blueprint but I don't know how to round the corners. I traced from the side which probably made more edges to curve.
      This is the blueprint
      This is the model that I have so far.
      • GaieusG
        You should watch green Toaster's thread about this:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=2650
        Also, there are other car tuts in the tutorial forum, like this one:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=10081
        • D
          DaRkM
          Thanks but Toaster's thread doesn't help much and that other one. Doesn't it just make everything rounded? Seems like it would make my car look like a bubble. This car isn't completely rounded.
            If you go there you will find one hundred of Nissan Skyline for test with your try πŸ˜‰
            you can try to use this funny powerful script Zorro
            for cut your volume in one line over it!
            And work on half part you will make a symmetry lateR.
            • D
              DaRkM
              Hi, I didn't do very good at tracing. could someone please clean this up for me?
              EDIT: I remade the trace. No need to clean it up now.
              EDIT 2: I can't seem to get this working. Can someone please fix the problems and possibly finish this?
              Model file is updated and there is the tutorial that I'm using.
              Nissan Skyline.skp
              Tutorial.skp
              • D
                DaRkM
                Well, I tried completing it. Not that good as I hoped but not that bad either.
                It's untextured but here are pictures. The spoiler was the best part of the car. I made that before the car.
                Right Corner view
                Spoiler
                Side view
