    Help: Floating model
    4 Posts 3 Posters 544 Views 3 Watching
    • A
      ARCHI_BUM
      When i display shadows, my model looks as though its floating or hovering over the ground. How do i anchor it?
      Thanks.
      • R
        remus
        It sounds like youve put your model above the ground plane (the red green plane in SU.) All you need to do is move it so it's level with the origin, then shadows should cast realistically.
        • GaieusG
          And remember; the "real" ground plane is always on the red/green plane of the original global axis set! So if you have ever moved or aligned your axes, right click on any of them and "reset" the original to see where you have to move your stuff.
          • A
            ARCHI_BUM
            Thank you very much - i had moved my axis so reseting it worked!
