    Can sketchup pro export textures with .3ds models?
    7 Posts 4 Posters 1.8k Views 4 Watching
    • I
      iamthatguy113
      I have sketchup free, but I was wondering if a .3ds model is exported with textures with sketchup pro. Also, is there a way to get sketchup free models (.skp or .kmz) to a .3ds .max or .obj format (either with or without textures)?
      • R
        remus
        I'm not sure wether .3ds models keep their texture, i'll check it out in a second.
        If you export your model as a google earth 4 file, change the file extension to .zip and then open it up, the model is stored as a .dae file, which you can import in to blender and then resave as whatever (.3ds or .obj in your case.)
        • R
          remus
          After the quick test, i can say that SU does indeed export textures with the .3ds files.
          • J
            johnsenior1973
            There is a ruby for exporting as an obj from the free SU (without textures). Can't find it at the moment. I'm looking though and will post if i find it.
            • J
              johnsenior1973
              http://sketchuptips.blogspot.com/2007/09/plugin-index-page.html
              • GaieusG
                Ah, yes, Jim's exporter.
                Note that a direct export from SU to 3ds will export either your texture UV maps or your welded vertices. Alan Fraqser wrote a nice tutorial on the old forums that I was supposed to "transfer" here but sigh... so little time!
                • I
                  iamthatguy113
                  I just tried the .obj export plugin, it works great! Thanks for the help
