    [Plugin] Trilateration (Update)
    24 Posts 14 Posters 30.5k Views 14 Watching
    • O Offline
      obones
      Yes, I do, but debugging it, I found out what's wrong:
      Basically, I input values that would give a really thin triangle and so are "out of range" for the computation to work. It thus calls UI.messagebox to display an error message.
      However, on my system, this dialog box is showing behind the main Sketchup GUI, meaning I can't see it.
      The only way to bring it back on top is to Alt-Tab to other applications and back.
      • sallyS Offline
        sally
        Hello Didier, will you be updating this for SU 2020. I am lost without it!! Complement perdue!
        Merci beaucoup 😄
          @sally
          It isn't signed for newer SketchUp versions, but it should still work if you have your Extension Manager's > Extension Loading policy set to 'Unrestricted'...
          Install it and try using it with the Ruby Console open...
          If it works, fine - if it fails, then at least you'll see some error messages ??
          Many older plugins are no longer being supported, and so they aren't signed for newer SketchUp 'full-compatibility' - however, many of them will still work...
          • Didier BurD Offline
            Didier Bur
            I haven't SU2020 yet, but it works with my SU2019, apparently just a matter of loading policy, as TIG said.
            DB
            • 2 / 2
