    [Tutorial > Modeling] Hamburger
    21 Posts 6 Posters 4.4k Views 6 Watching
      cloverleaf
      hi coen, im following your tutorial, but im stuck with creating the dome shape of the first bun, i can't follow how you were able to just click once the surface and the dome was created. this is where you click the edges of each halves then change the tool to follow me(not sure if its the right tool). i tried doing this but whenever i change the tool the selected edges are not selected anymore.
        Hi cloverleaf ,
        Yes they seem to be not selected but it doesn't matter. Just click on that face and it will work.
          cloverleaf
          hi gaieus, thanks for the reply, ive tried it a couple of time using the follow me tool, but i end up doing something like this. 😞
            I don't even know how you could achieve that! 😲
            Were the circle and the arc face properly aligned?
              cloverleaf
              well, what i did was set it to parallel projection, set it to top view, created the circle with 1m radius, then draw a center line and last i rotated it.
              after that i could not recreate the dome shape with the follow me tool.
              i get different kind of shapes with the follow me tool.
              maybe there is something im doing wrong here?
              the attached picture is the best dome that i can create but its not what i wanted.
                You draw a centerline - that's OK (is it surely a centerline?). Than you draw an arc from the two ends of the centerline - make sure to draw the arc on the z axis othewise you can get weird results. To do this, orbit your model into a view where you see it more from the side than from top. It will inference on the z axis with a little popup.
                  cloverleaf
                  im sure that i have the line on center, ive also tried your suggestion to create an arc on the z-space but i still cant produce a dome.
                  can you check my model? il post it here.
                  hamburger.skp
                    Hm... I guess that after selecting the edges, you wanted to extrude the horizontal faces, right? Doing it so I could reproduce your weird shapes. πŸ˜‰
                    Now do it like this:
                    1. select the edges of the two hlaf circles on the horizontal plane only
                    2. select the follow me tool and click on the verical plane created by the centerline and the arc.
                      cloverleaf
                      the vertical plane did it! 😍 thanks gaieus!! πŸ˜„
                        πŸ‘
                        • ely862meE Offline
                          ely862me
                          Bon appΓ©tit! πŸ˜„
                          u forgot the Coca-Cola and some potatos and some (S)ketchup πŸ˜†
                          Elisei (sketchupper)
                          Come and See EliseiDesign
                            scottiw2000
                            Thanks for a helpful tutorial. What is the tool you use to deform the meshes for the cheese and lettuce? I really need something to curve surfaces like that, but I haven't been able to find it.
                            Thanks!
                              Hi Scotti,
                              That's the Sandbox tool. Go and have a look at it in the SU Guide (somewhere in the middle of the menus).
                              The From scratch and the Smoove tools were involved.
                              You have to enable it first from the Window (menu) Preferences > Extensions tab.
                              • P Offline
                                pav_3j
                                may i ask what that variation to the move cursor is?
                                i find it intriguing, and is clearly something i have missed!
                                good tutorial by the way, made me very hungry.
                                pav
                                Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                  What variation?
                                  • P Offline
                                    pav_3j
                                    it just looks odd to me? maybe mine is wierd.
                                    am i being stupid here?
                                    i probably am...
                                    he he
                                    pav
                                      No, C'mon, Pav,
                                      It's just sooo long I don't want to watch it again 😞
                                      If you mean the + sign next to it, it is Copy/Move (Ctrl+Move tool)
                                      • P Offline
                                        pav_3j
                                        @gaieus said:
                                        No, C'mon, Pav,
                                        i'm not that silly dude! he he
                                        have worked out what it was though. i feel kinda stooooopid for saying, but basically i dropped my computer screen while in transit the other day, and i appear to have a small collection of "dead pixels" in my screen, which i somehow managed to line up with the move tool on the video.
                                        feel like such a fool...
                                        sorry for wasting your time!
                                        pav
                                          No prob, Pav, and sorry to hear about the accident. πŸ˜‰
                                            scottiw2000
                                            Thanks! It would have taken me a long time to find that. Great tools, though.
                                            • 1 / 2
