    Request for RUBY
    19 Posts 7 Posters 4.3k Views 7 Watching
    • Mike LuceyM
      Mike Lucey
      Hi Guys,
      I rarely make requests for Ruby Scripts but have one now.
      I wonder would it be possible to make a Ruby that would
      show the Line Extensions at 1 pix while at the same time
      allowing the Main Construction Line to show as 2,3, etc in
      Profile.
      This is a through-back to my days of manual drafting. I
      always extended the line (light pencil) beyond the main
      construction line and then blocked in a heavy pencil or
      pen / ink.
      I hope you understand what I'm getting at here. If not
      I can post a picture.
      Thanks for reading.
      Mike
      • D
        dudekracked
        hi mike,
        have you tried the styles in sketchup? i think the styles can mimic the manual drafting style.
        • Mike LuceyM
          Mike Lucey
          Hi Dudekracked,
          Thanks for the suggestion but what I have in mind is not covered
          in Styles. 😒
          Mike
            Mike, does this sort of illustrate what you have in mind?
            http://img.photobucket.com/albums/v506/weekender410/MikeLuceyb.jpg
            • Mike LuceyM
              Mike Lucey
              That's Spot On Dave πŸ‘ I wonder is it possible ?
              • A
                a4chitect
                remus: this is not achievable using the styles only, because mike wants to have the profile thick and extension lines thin...
                mike: only simple way is to export 2 images (one with profiles, one with extensions) and merge them in photoshop or any other capable raster image editor
                  Actually, I did it all in SketchUp. No PhotoShop or other image editor was used.
                  • T
                    todd burch
                    Looks like a lot of manual work and hidden stuff to do it. If it can be done manually, it can probably be automated.
                    Todd
                    • T
                      todd burch
                      Mike, you really need to smile more. πŸ˜„
                        Todd, it was really that much work manually but automating it would be a good thing. Doing it for a single scene is really no big deal but to do this for multiple scenes would be tedious at best. I made an image export with Extensions on and Profiles off. Then I switched those settings and created a watermark using the just exported image as an overlay. Here's another example.
                        http://img.photobucket.com/albums/v506/weekender410/americanbung2.jpg
                        The problem is that the white areas in the overlay have a masking effect on the model. Now, if it was possible to export the watermark image as a PNG and make the white areas transparent (is that alpha adjustment?) before making the watermark, this wouldn't be a problem.
                        As an auotmated thing I could see something along the lines of ADO, exporting images for each scene. Then those images would be imported to make watermark styles that are applied to the associated scenes. Might be a good time to get up for a cuppa.
                        • R
                          remus
                          styles->edit->edge->extension πŸ˜‰
                          or were you thinking of having it as actual geometry?
                          edit: re-read your post and see what you mean now.
                          • J
                            JGA
                            re: "The problem is that the white areas in the overlay have a masking effect on the model. Now, if it was possible to export the watermark image as a PNG and make the white areas transparent (is that alpha adjustment?) before making the watermark, this wouldn't be a problem."
                            If you use an image editor which has layers, set the layer property to multiply. White is ignored while the lines remain.
                            Regards,
                            JGA
                              Yes, that can be done manually. The point though is to hopefully automate this with a plugin. I expect the problem with automating it is getting the white to be made transparent since that doesn't seem to be available in SU.
                              • Mike LuceyM
                                Mike Lucey
                                LOL, I'll smile if you organise that Ruby for me πŸ˜„
                                Ah! that my pasport pic about 5 years ago. Yes I do
                                look stern πŸ˜’ Must change it πŸ˜‰
                                Done Todd, is that okay? Looking forward to meeting
                                you in Mountain View πŸ‘
                                • Mike LuceyM
                                  Mike Lucey
                                  Thanks Dave for explaining the Workaround πŸ˜‰
                                  • T
                                    todd burch
                                    Mike, you don't look a day over 35 when you smile. 🀣
                                      My pleasure. Better picture, too. πŸ˜‰
                                      Dave
                                      • Mike LuceyM
                                        Mike Lucey
                                        I've got shoes that are older than 35! πŸ˜„
                                          Must be shopping in the used clothing shops. πŸ˜„
