    Tack House to Restaurant!
    11 Posts 8 Posters 977 Views 8 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Hi Guys,
      I thought you might enjoy viewing this little project that I'm
      working on a present between times that I'm not hanging out here πŸ˜‰
      Its part of a Golf Holiday Village project that I'm involved in.
      The building in question was a very derelict Tack House (I think).
      The Tack House was part of a large Landlord's Estate and the place
      where horse related stuff was stored, saddles, harnesses etc.
      Two years ago the building was renovated and converted to a 3 bedroom
      holiday home. We simply slotted a timber frame structure inside the
      existing walls and put a roof on it!
      It is now required to change its use to a small restaurant and shop.
      I have just completed a draft design which is being considered at
      present. The attached images show what it was and what I would
      like it to become.
      I was glad to have Tom's great trees to hand as they resemble what
      is to the rear of the building.
      Mike
      • DanielD Offline
        Daniel
        Looks great, Mike. But why did you plaster the stone wall on the end of the existing building?
        My avatar is an anachronism.
        • marked001M Offline
          marked001
          love the composition with the trees..mike! wish you could do something similar with the grass.. that'd get it over the top πŸ˜„
          http://www.revision21vis.com
          instagram: revi21on
            johnsenior1973
            Nice that the lonely tree got some friends around to keep him company. πŸ˜‰
              Mike Lucey
              Thanks for the comments guys. Daniel, the stone work was so bad
              on the gable that plastering it was the only option. The best of
              the stone was on the front wall.
              Yes Jason my grass leaves a lot to be desired. I must look for
              better stuff πŸ‘
              John, I just repeated the trees as this was just a quickie. I was
              more interested in getting the new layout right. I can post this
              if anyone is interested.
              Mike
                dylan
                That is nice Mike and sounds like a pretty interesting job.
                Good to see you added the flashing and ridge tiles for extra detail πŸ‘
                I must say, Toms trees do look good πŸ˜„
                http://dmdarchitecture.co.uk/
                  mateo soletic
                  Mike,
                  Nice and interesting project.
                  About grass..
                  http://www.brushes.obsidiandawn.com/sets/grasses.htm
                  Here are some photoshop brushes free to download.
                  Cheers,
                  Mateo
                  Concept Illustrations
                  • P Offline
                    pbozarth
                    I definitely like the trees, are they sketchup entourage or did you make them in photoshop? I feel like the edges in your drawing are a little jaggedy, if you export the colors with the lines turned off and use that as a raster image, and then export the lines as vectors like eps or dwg, you can place the vectors over the raster image, and get nice crisp lines that will never get jaggedy.
                      Mike Lucey
                      Thanks for the comments / suggestions pbozarth. The image was only
                      a quickie screen grab directly from SU. I will post some further
                      images once I have got some more work done.
                        tomsdesk
                        Mike, beautiful existing stonework...kuddos on saving what of it you could! When I was working further north in Kansas, the Flinthills area, we did quite a few saving's of old limestone structures: some by building inside, some by adding an envelope and exposing the inside.
                        How much of the design shown is new addition to the house stage of use?
                        (Oh yeah, the trees are ok too...I guess :`)
                        2.5D Trees & Shrubs!
                          Mike Lucey
                          Yes Tom, I like to preserve the past otherwise we forget where
                          we came from πŸ˜‰ As I said the front wall was the best of the
                          stonework and this has been saved and repointed.
                          It will be visible from the outside (at Ent Porch) also from
                          inside the proposed lean-to that will accommodate dinners.
                          Again, thanks for the trees πŸ‘
                          Mike
