    Dotted lines after dragging cursor?
    2 Posts 2 Posters 437 Views 2 Watching
    • J
      Johnnyjack777
      Don't remember this problem last time I was using,
      Anytime I click-drag the cursor, (Like selecting multiple items or the push/pull tool)
      All the edge lines onscreen change to that same broken line the select box is in and won't change back until I do something else...
      Nothing I haven't been working around, but it gets very hard to see 1/2 invisible lines πŸ˜„
      Any ideas? Either way, thank you for your time.
      • GaieusG
        Hi Johnnyjack (and welcome).
        This really sound like some video card issue. Try to go to Window > Preferences > OpenGL settings and first turn off Fast Feedback. If this doesn't help, turn off Hardware acceleration as well. This (finally) should work however it may affect performance especially with more complex models.
        The ultimate solution would be to update your video driver and see if that helps.
