    How to get the SU thumbnails back in Windows explorer?
    6 Posts 4 Posters 1.8k Views 4 Watching
    • K
      kwistenbiebel
      Hi all,
      I am experiencing an old issue. One that I had earlier, fixed it once but forgot how to 😳 .
      I installed Sketchup on my new PC (vista 64bit) and the image thumbnails don't seem to work in the Windows explorer.
      Is there a way to get them back? It is damn hard browsing for models when I can't have a visual preview of them.
      Thanks for your input.
      Regards,
      Kwistenbiebel
      • D
        dudekracked
        hello kwistenbiebel,
        you can use xnview to view your sketchup models, there is also an xnview ruby made by Burkhard
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=4905#p26281
        • K
          kwistenbiebel
          Good suggestion Dudecracked .Thank you.
          ...though it would be even better if it would work with the default windows explorer .
          If I remember correctly, the issue can be solved by first installing SU 5 and after that SU 6.
          However, this is a tedious workaround I am not up to...
          I'd like to keep the new PC clean from useless installs.
          • D
            dudekracked
            im not too familiar with vista os but the previews should be available after you install skp6, maybe it is something to do with file type/registration (not pretty sure ❓)
            i myself like to keep programs in the computer to a minimum, you can use the no-install xnview, the zip file for the meantime, just be careful when you start it first to choose the .ini setting.
            • R
              remus
              Try this kwist: get a skp file, right click on it and go prperties. There should be a little thing that says 'opens with' make sure this is set to SU then restart your computer.
              • J
                jhauswirth
                cd to the same dir as sketchup.exe.
                Run-
                regsvr32 ThumbsUp.dll
                It should say succeeded.
                If not, I seem to recall that since the dll is not 64-bit, it won't work in 64-bit Vista.
