Dots stay when drawing
Hello!
I just started using SketchUp, and faced an annoying thing. When I try to draw a line for example, and I'm trying to place a starting point for the line and move the mouse, the starting points stay there and a new one comes whenever I move the mouse, making the placing to right spot veeery hard. Is this a bug or what?
Its a graphics issue, if you go window->preferences->opengl and then uncheck the box that says 'use hardware acceleration' that should solve your problem.
I forgot to say, its worh unticking the 'use fast feedback' box first, as this wont slow down SU as much, although it doesnt always work.
Thx very much, I did this first and it solved the problem.
Register LoginAdvertisement
