    Exporting As 2D Graphic Problem
    13 Posts 7 Posters 6.8k Views 7 Watching
    • G Offline
      GreenSaints
      I've only been using SU for about a month, but I totally love it πŸ˜„
      I'm trying to make visual of one view but 3 different styles - basically 1/3 to look really sketchy (because I can't hand draw!! 😳) 1/3 to be semi coloured but still sketchy and the final 1/3 to be photorealistic (which I'm doing in Kerkytha)
      The first visual I did with a basic sketchy style worked as I exported it as an .eps and it opened in Photoshop fine, but I can't export the view with the semi coloured/sketch style. When I try exporting it as an .eps SU just hangs and crashes, and when I try exporting it as any image (.tif, .jpg, .png) it says "Failed to save file C:....." 😒
      Any ideas what I can do?
      • soloS Offline
        solo
        What size are you exporting it?
        http://www.solos-art.com
          Yeah, I had the same idea... File size (resolution in this case) might be a problem if you run out of memory.
          • AnssiA Offline
            Anssi
            And, if you are exporting an image wider or higher than, say, 3000 pixels, you should turn off Antialiasing from the File Export options.
            Anssi
            • G Offline
              GreenSaints
              Sorry for the late reply.
              After reading your replies, I might have been exporting the image too big. Just checked it and it's 7200x3671 😲
              Shall I just export it as the view size and make it bigger in PS?
                No, that would most probably look ugly. However 7200 is pretty big. If you don't plan to print it big, something around 2000 would be perfectly enough. Make sure to export the image at the same resolution from Kerky (you can simply overwrite the preset default export sizes manually).
                  remus
                  First thing to do is turn of anti aliasing and see if you can export it then. If that doesnt work, just slowly decrease the size untill you can get it to work.
                  And listen to what gai says, it's good stuff πŸ‘
                  • G Offline
                    GreenSaints
                    Thanks for your replies.
                    I need to print it pretty big - it's going on an A1 poster.
                    I had to make the graphic at the default image size (1214x619) because it kept dying 😒 I'll have to increase it in PS.
                    Also, I had to keep the Antialiasing on because one of the styles I have used didn't work when I turned it off
                    • G Offline
                      GreenSaints
                      Problem solved 😍 thanks to my new best friend remus! πŸ˜‰ 🀣
                        remus
                        no problem πŸŽ‰
                          swedishnitro
                          As a rule, I export at 4000 pixels when I do my views in PS, and it easily fills an A1, and thats 72 dpi with no discernable loss of quality - my advice is up res to 200 dpi in PS if your machine can handle it.
                          http://www.jordanjlloyd.me
                          • G Offline
                            GreenSaints
                            Thanks for the advice πŸ˜„
                              jody.walker
                              I am having this same issue, and I need to print on 36x48 for a presentation!!! The highest I can get it to export is 2,600, and that's with anti-alias turned off. I'm running SketchUp Pro on a Pentium 4 running at 3 GHZ, w/ 4 GB of RAM. My only guess is that it could be the video card, but its an ATI FireGL V3400 w/ 128 MB. Any ideas?
