    Plugin Glue needed?
    6 Posts 5 Posters 701 Views 5 Watching
      mcat
      I have two objects and I want make "glue" 1 and 2
      but how?
      I want plugin or another method to make this:
      I select first object then I select 2 object then
      turn on glue plugin
      second object move to first object and "glue"
      to him (slit between 1 and 2 is zero milimeters)
      Forgive my ponglish...
        Sawduster
        If you are just wanting to move one object over next to another and have them become a single object, there are a couple ways of doing that.
        If the objects have not been made into components, simply select one, turn on the move tool, grasp the object at a place that will index it to another specific place on the second object and drag it into place. Once it is released in contact with the other object, they are joined together.
        If they are made into components, do the same and then select both items once they're together, select both items and make them into a single component.
        May all your dimensions be the sum of their total.
        Jerry
        http://www.sawdustersplace.com
        • O Offline
          othmanalazzam
          there is a plugin called SuperGlue,, search for it on the extensions warehouse in sketchup
          • cottyC Offline
            cotty
            I think the OP don't search for this type of gluing? Maybe I'm wrong...
            my SketchUp gallery
            • BoxB Offline
              And I have the feeling he may have found a solution at some stage during the last 6 years.
              • cottyC Offline
                cotty
                πŸ˜’
                my SketchUp gallery
